1993 Honda 35HP Lower Unit Removal
TimR53150
I need to change the Impeller for this motor and am wondering how this procedure differes from the Johnson V6 motors I've done in the past. I see 4 bolts that hold on the lower unit and the shift linkage below the pivit arm. What else am I missing or need to know? Do I neeed the motor in FWD gear?<br />Thanks in advance for your help!<br />Tim Ross
Bear
Re: 1993 Honda 35HP Lower Unit Removal
You are missing the fifth bolt under the fin.<br />Count the threads above the nut for the shift linkage and write it down. If you put it in gear the nut is easier to reach.<br />Good luck!<br /><br />Edit: Just saw that your post was from May 8, I guess you are done by now...
