I am desperately trying to remove the lower unit on my 8 hp Honda, year 2000. I guess the BF8A and BF100 are the same model. I removed the 5 bolts under the anticavitation plate, and pulled the unit down an inch. It won't come off, since it is still connected to the shifter rod. How do I disconnect it from the shifter. A fast reply would be greatly appreciated. <br /><br />Also, I tried pulling on it, before I figured out the shifter was connected. The axel going into the prop came out an inch. I pushed it back in. Is there a way to find out if I damaged anything? It looks fine, but I'm new to this whole thing. <br /><br />Also, this is my first time with any kind of motor, and I am trying to replace the impeller without a shop manual. I plan on buying one, but I want to use the engine in the next few days. Does anyone know where I can find intructions to install the new impeller, or do any of you have any tips? Thanks so much.<br /><br />Best - Bryan bprender@uiuc.edu
