I just bought a used 1995 Tohatsu M50D. I drained all the oil out of the oil reservoir because I was told not to mix the oil. I now need to bleed the air out of the line. I know there is a screw on top of the oil pump that is used for bleeding air but what is the actual procedure? Do you run the engine or pressurize the oil lines or???<br /><br />I bought the Tohatsu service manual but it is VERY skimpy on details. It says:<br />1- Fill the oil tank<br />2- Loosen the bleeding screw<br />3- Bleed the air<br />4- Retighten screw<br /><br />Does the air bleed out all by itself?
