pondhopper
- Oct 24, 2004
- 34
The water on my Honda is not coming out like it should. When it is idling, it dribbles out and at full throttle it DOES increases stream presure but still doesn't stream stong. The water is pretty hot when it's coming out. (I'm not familiar with boat motors and don't know if it should be luke warm or boiling) I've notice a few people have had this smae type of problem. Before I tear into everything what should I check first? Also, is there a easy way to pull out the water intake screen/filter. It seem a little plugged (not bad).<br />One more thing, has anyone order the gaskets for the the gear oil drain and level bolts over the internet? If so, where did you get them and how did you figure out the part number.<br /><br />Thanks,
