Re: convert a tohatsu 90hp from 25"shaft to 20"
Matt, if the lower unit is drained of oil, remove the drain plug so that you are not pulling against a vaccuum. Also, there is an O-ring there, you may want to have a fresh one handy just in case. Good luck.
