Re: Honda 100 impeller question
Hi,<br /><br />I just rebuilt an older BF 100 so I may be able to help. <br /><br />If your engine is blue (shaft), yellow (propeller), grey (engine) and white (hood), it is in the 80's era. There is a serial number punched into the engine block - if you are facing the engine from the front it will be visible just under the fly wheel, above the gear linkage. <br /><br />Clymer makes a useful shop manual for Honda motors from 2-130 HP ranging from 1976-1999, issue number B757.<br /><br />In terms of the impeller, just take the existing one to the parts store and they would be able to match it, or if you find the serial number on the engine block, they will be able to match the right part. <br /><br />To remove the lower end, you need to remove the "shift linkage connector" which is located on top of the "shift shaft". Basically, it sounds like you know where this is located. You need to remove the rectifier by removing the one bolt holding it down (use a 10mm socket). Then remove the cotter pin from the rod that holds the "shift linkage connector" to the shift lever. You have to unscrew (counter clockwise) the "shift linkage connector" completely off the "shift shaft" to be able to remove the lower end. This is easily done when the gear is shifted in forward - but you may need to remove the arced piece with the roller on it to be able to completely move the shifter out of the way. I was doing this with the engine removed so I had complete clearance. <br /><br />I send another message after this one since I'm running out of characters.
