honda tilt and trim
wdwbruce
Where do you fill the tilt with fluid the motor is a 2000 130 honda are there any tips to bleed air etc.
MajBach
Re: honda tilt and trim
I was told by my Honda dealer that it is not a serviced part. I inquired about changing the oil and they said not to.
hondon
With the engine tilted all the way up,the tilt locks in place,and you looking at the back of the boat ,that resivior cap will be the small somewhat bulbous cap looking thing towards the right and top of that whole tilt assembly.With several rags and a drip pan ,remove that cap SLOWLY, then fill with the correct fluid, good to go.Why are you in there in the first place?
wdwbruce
The motor will not tilt up or down but you can hear the tilt motor running so I thought it might need fluid.
radsrh
There is a manual release screw on the port side of the motor, turn it to release the tilt and have a friend or two lift the motor up. Make sure you set the locks, and you will be able to check the level of the fluid.
