I have an older Honda BF-100 outboard (1982, 9.8hp). I haven't used it for about six months (ran fine then). Now, when I try to start it, it starts OK with full choke and runs with about 7/8 choke but the moment you try to push the choke in any further, it revs up and then dies. I've tried mucking with the air screw -- no effect. Tried cleaning out the carb with spray. No effect. Cleaned the fuel filter. No change.<br /><br />If I carefully hold the choke at about 7/8 (out), it will run (pretty well too). But again, the minute I push it in, the engine revs up (like it does normally when getting more air) and then just quits.<br /><br />Any ideas?
