SpokaneDan
- Sep 7, 2003
- 3
I have an older Honda blue and white 10HP B100. It will run until warm then lightly smoke (blue)just before dying. If you pump the fuel bulb it will recover and run for about 5 minutes. the fuel pump appeared to not be working so I replaced it and all of the fuel lines, but the problem still exists. The fuel pump will pump great when cold but as the motor heats up and/or you increase the rpm's the amount of fuel decreases to the point of almost stopping. I tried a different fuel tank and line with the same result. It also does not seem to have as much power as it used to either. Any suggestions?
