I am having a head reworked,(magnaflux,leveled,valves ground and seats reworked)an there was a bad headbolt that someone had replaced with a short 7/16 auto headbolt. I was able to use helexcoil to renew the block to accept standard honda head bolt but I am concerned with a small amount of pitting arround the repaired bolt hole. Is there a high temp gasket sealent that I should use with the head gasket install. thanks in advance sluff
