This outboard has internal .4 gallon tank. Run time 40 min. max. How can I run a line with bulb from external tank to this motor? Any suggestions would be interesting. Thanks
i dont think you cam because the tank on that motor is gravity feed and does not have a fuel pump.if you can get the tank higher then the engine you will be ok. but i dont think thats gonna happen.you can always carry a gallon or 2 jug with you nad fill it as needed
You would need to install a fuel pump<br />and of course the appropreate fittings.<br /> Youll need to find a place on the crankcase<br /> to hook up the pulse port for the fuel pump.<br /> Wouldnt hurt to check with a dealer to see if there is a remote option.
