Honda BF50 Oil Leak
dd716ted
I have a new Honda 50 HP that leaks a slight amount of crankcase oil from the oil pan drain plug. First I tightened the drain plug as tight as I dared to and second I drained the crankcase, replaced the crush washer on the drain plug and refilled the motor with oil. It still leaks a trace of oil over a 48 hout period (less than a teaspoon). Has anyone else experienced such a problem and if so, what corrective action was taken? Have a nice day on the water.
