Re: "Wanted" Wiring Diagram For 1980 Honda 7.5HP
Yellow wire comes from cdi unit to the light then<br />to the oil pressure switch where it is then grounded to complete the circuit.......if your<br />engine is the older model of bf 75 (serial no's<br />pre. 120.000) with the breaker point's ignition the yellow wire gets its<br />supply from the charging/ lighting coil then the light and then to the oil switch. Jim
