HONDA 115 TILT & TRIM
EKGH2N
DOES ANYONE KNOW IF IT IS NORMAL WHEN RAISING THE MOTOR THE HYDROLICS MAKE A WEIRD SOUND? I JUST GOT THE BOAT HOME FROM THE DEALER AND WAS RAISING THE MOTOR TO HERE THIS CRACKLING SOUND IN THE FIRST STAGE ONCE<br /> THE MOTOR IS PASSED IT IS FINE. THE DEALER SAID THAT WAS NORMAL ON HONDAS IS THIS TURE OR B.S :confused:
D
DJ
Guest
Re: HONDA 115 TILT & TRIM
You've got air in the system. You will also hear it when you are using the trim at cruising speeds. You'll swear the transom is cracking.<br /><br />Take it back and tell the dealer to bleed the trim system.
