Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Tohatsu 5 horse 2 stroke manual?
  • Tohatsu 5 horse 2 stroke manual?
    Need the manual. It is an early 90's Nissan. Anybody have a PDF? Had a dirty carb. Cleaned it but now it won't turn over even with starting fluid. I did something wrong and will need to follow manual. Thanks!!
    Service Manual only has basic info, remove plug, short it to ground, pull cord and check if with healthy spark. Connect red kill cord. One thing that find on 2 strokes 5 HP- OB's is that the black wire that connects to Ignition Coil terminal comes bit wider than it should and connector is not plugged firm to IC, with a plier close a bit connector to achieve a tight fitting on contact.
    Happy Boating
    Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
    • #3
      SERVICE MANUAL : 1 & 2 CYLINDER 2-STROKES
      Description Covers all 1 & 2 cylinder 2-stroke models.
      Part #: 003-21035-1
      List Price (MSRP): $50.00
      Paul
      Buffalo NY USA
