Tohatsu 2008 TLDI 40 won't start and if it does bogs
thatone123
Banned
Like new, low hour. The fuel hoses were messed with, just the main one to the tank. The primer bulb seems not to get as hard as it should and takes a lot of pumping. I think gas is not getting to the injectors or the fuel pump. I understand that this can be air in the fuel lines and needs to be re-coded and the air bled out at the dealer? Is there a way to do this myself or is that more to the problem?
TOHATSU GURU
Get a service manual and put the engine into diagnostic mode. It will tell you what is wrong.
