I am posting this for my Father in Law who has been having an issue with his 2006 Honda BF 90 outboard.
Situation: Engine idles fine at pier but after 20-25 minutes of running it in gear, the engine sputters to low RPMs then shuts off. When this happens, the engine will not restart for 5-10 minutes. After restarting, engine runs fine for few minutes then shuts off again. It seems to be shutting off once it heats up.
At first, I thought the engine was getting starved of fuel so I replaced entire fuel system (fuel lines, fuel water separator, pick up tube, primer ball). I made sure all connections were tight. I checked old fuel water separator for water in fuel. I checked fuel in fuel tank for water. No water found. I added new fuel to tank, fuel water separator, and bled carbs to remove any old fuel.
To ensure fuel in fuel tank wasn't causing the issue, I connected a new portable fuel tank with new fuel directly to engine and engine still shut off as described above.
This led me to my current idea of engine overheating since I know its not a fuel related issue. No alarms sound when it shuts off, but we went ahead and replaced the thermostat in the powerhead. The carbs have been recently cleaned.
Researching online today, I believe it could be an issue with the CDI? Any advice/recommendations would be greatly appreciated. I'm stumped. Thanks in advance.
