How do you check accelerator pump on carberator?
M m1man Cadet Joined Apr 30, 2017 Messages 7 May 5, 2017 #1 How do you check accelerator pump on carberator?
Sea Rider Supreme Mariner Joined Sep 20, 2008 Messages 12,345 May 5, 2017 #2 Same post asking same as previous one. That's for TG or Paul to provide a proper answer. Happy Boating
pvanv Admiral Joined Apr 20, 2008 Messages 6,509 May 7, 2017 #3 The pump operates by squirting liquid fuel into the air stream when opening the throttle quickly. There are ball checks that keep it full until the plunger is moved, and cause the fuel to go out of the casting through the squirter.
