markomarkovich
- Feb 23, 2017
- 6
Long story short, motor was underwater in ocean for a week, once taken out i took it home and dunked it in fresh water, cleaned it all up, tried to start it and no go. sprayed it down with WD-40 on the outside and put it in storage. This week i ordered a new pump body, pump cover and all new gaskets for it. I put it all in and for some reason no fuel was going to the carb bowl it was dry, so i took the bowl apart and filled it up with fuel, put it back together and now it seems to be full and maybe the fuel is getting to it. It almost started up a few times in the beginning and now that the bowl is full I'm not getting it to kick over even for a second. I tried using a lot of starting fluid but nothing at all. I disconnected the brown wire for the kill switch and put it back on and still nothing. Any ideas what the problem may be?
I am getting spark as well.
