rhunter73
- Apr 29, 2013
- 13
Just want to re-affirm that the You-Tube Videos regarding the 2 and 4 stroke 2-9.8 water pump replacement are correct.
1. Drift out the bottom roll pin on the shift rod.
2. Unscrew the four screws from the bottom unit.
3. You need help at the last screw, otherwise the unit will fall.
4. Dismount the bottom unit, it is about 10 lbs.
5 Unscrew the four screws around the plastic housing unit.
6. replace the impeller in the metal unit
7. back up the installation, be patient.
8 be patient
9 take your time.
9.1. Screw in the four screws in the bottom unit. You may need to move the shift lever.
takes about 20 minutes for a dumbo like me. You need a 10mm box driver set.
http://www.iboats.com/Water-Pump-Im...5108747--session_id.449205100--view_id.485903
8 be patient
9 take your time.
