hipster dufus
- Jan 1, 2009
- 169
use high octane gas w additives for winter storage on my 30 hp efi 4 stroke tohatsu. put about a gallon in the tank,non ethanol, and start engine every 2 weeks and idle for 10 minutes during the 2 month down time. took my rig out today, had an extra gallon of new non ethanol with me. wanted to run tank down and then fill up with new gas. old tank was mixed w seafoam and stabil.engine started to act like it was out of gas then warning lamp and beeper started flashing. shut down, checked oil level ,looked good. filled tank up with new gas, primed and started. ran fine on way back to ramp. checked manual, maps sensor. could running out of fuel cause this?oil not the issue. water pump serviced at 120 hrs. engine has 149 on it now. someone allay my fears.
