Hi All, I have a problem that I am trying to figure out. before i changed the oil, I noticed that the green light would not stay on and figured there was an oil issue. I changed the oil as recommended to 1.2qts. first start the green light came on and then shut off in a couple of seconds. After that it seems to only stay on at high rpm. The second I lower the rpm it shuts off. What do you think the issue is and how do I fix this? I did notice some oil dripped out from the foot near the prop and the little hole near the top foot oil plug but I am unsure if it's the old oil or the new oil. I checked the dip stick and it looks fine.
