Will try and not be long windend. Old 45 Four Stroke. Runs like a bat out of hades for a couple minutes. Starts perfect, idles fine. But "almost" dies after 2 minutes of running hard. Will run all day long well at low idle. You can almost put a timer on the time it takes for the motor to stall. It doesn't cut off all together. Pull off throttle and wait 30 seconds and will run wide open again. Thinking fuel related I have changed all hoses, filters, tank and using only Ethanol free gas. Spark is good on all cylinders. White smoke (does smell like fuel) when bogs down. HELP!! I am not dumb, I promise. I would re-do carbs but I just don't think it can be carb related. Desperate for advice.
