2001 9.9hp Honda Kill Switch
ICamel
I could have asked this a little more clearly. My 2001 9.9 Honda kill switch is only a push button switch. It does not have a lanyard that will kill the motor when pulled. I bought a kill switch that does have a lanyard. This switch has four terminals on the back side of which only two are used. Two terminals are used if the power interrupt goes through the magneto, or the other two terminals are used if the power goes through the coil. Since there are only two wires inside the tiller handle going to the current set up, I was wondering if the knowledgeable people here would know which terminals I should hook up the wires to.
ICamel
I received my Honda Marine Shop Manual today. The answer is it goes through the coil.
