So last week, after running all day without any issues, my motor decides it will only run at full throttle. It was slow to start, but if I choked it and floored the throttle it would fire up and run just fine at higher rpm's. It may keep running at 3/4 throttle, but as soon as I back off closer to 1/2 it dies. Docking was difficult, to say the least. My first thought was that the low speed carb jets were clogged. Back home, I dumped the gas, replaced it with fresh, non-ethanol gas with seafoam, broke down and cleaned the carb thoroughly, replaced the spark plugs, and cleaned out the fuel filter. When I then started it up, it seemed to idle okay for a couple minutes, then resumed exactly what it was doing before. Seems like a problem with the fuel system, but could the stator also have something to do with such issues? I would think if the fuel pump was going out it would have the opposite problem, running at low but not high rpm's. The motor is a 2-stroke Tohatsu m50c, and had been running just fine for quite some time without any recent tweaking or adjustments. I'm out of ideas at this point, any advice or suggestions would be greatly appreciated! Thanks!
