jakedaawg
- Jun 26, 2012
- 4,275
So, we have what we believe to be a 2003 BF50A3LRTA. Motor starts and runs fine cold or warmed up. The problem happens after you put it back ito neutral after having run it from a cold start. It idles too high to want to atempt to put it back into gear once the engine is warmed up to normal operating temp.
Nobody has messed with any linkages. All the paint and such marking the placement of the various adjustments are unbroken and still lined up.
The cables appear to be working properly. When it is warmed up and goes into this high idle the cam follower roller is free in the slot of the throttle cam. The throttles are closed.
What I am thinking is that for some reason when warm this engine is advancing the timing. I have not put a timing light on it yet to verify but am pretty certain it is not a carb/fuel issue.
My question are: How does this timing system on these hondas work? I am primarily an evinrude and yamaha tech. This is for a friend. What determines idle timing and how does it work? Am I going to need to hook this up to software that I do not have or is there a mechanical timing advance that I can check? There seems to be some sort of vacuum operated throttle control but it is not activated as far as moveing the cam and hence the throttle plates. I have visually verified that they are all closed at idle both when cold and when warmed up and the issue is occurring.
