1991 force L-drive, I need a seal that is no longer available.
dan2744
Does anybody know a seal I could use that would work in place of F695735. It's the lower u-joint seal, I'm trying to find the closest match possible. Thanks!
Frank Acampora
Most Chrysler and Force engines used standard seals. Take the seal out without destroying it completely and bring it to your local bearing supplier. If you are lucky, they may be able to match it. Be sure to specify ALL stainless construction otherwise the shell will rust and you will be replacing it every two years.
