Ahill11
- May 31, 2015
- 9
over heated at one point Completely rebuilt engine. has new impeller, pulls water great, runs fine good compression only one problem.
after running, water began to leak from the exhaust port (I didn't take that off so old gasket was on it) then I replaced both gaskets. Water leaked a little so I tightened it and it was fine. however now the water is being diverted into the cylinders. [if I let the water spray from the exhaust port it runs like a champ, however I am sure its not adequately cooling the engine]
All I can think of is either it is getting into the cylinders from the head gasket or being pushed through the exhaust port somewhere and splashed into the exhaust port some how. Also I have no telltale or water stream. would a head gasket leak or a clogged exit port for the water cause this? I make sure head and cylinder passages were al clear when it was apart..
Anyone have any input or suggestions? Im running outta summer!
thank you
thank you
