Hello Folks, hoping someone may be able to shed some light on my issue. rebuilt all 3 of my carbs, I noticed that the lower & Middle carb have like a jet hole or 'over fill' type of hole just above the bowl, however, the top carb does not. well after rebuilding the carbs, even though I tested the floats before re-installing them to confirm the needle was seating correctly when the float is all the way up, the middle carb is leaking fuel out of that Jet / weep hole. so I replaced the needle, & retested & still doing the same thing! RRRRGGGHH! these carbs do not have removable seats as far as I can tell, can anyone else confirm this?
I noticed the needle has a rubberized type of tip. Just though I would ask around before i blow $100 bucks on a new carb.
Thanks much!
Thanks much!
