Powertune having no affect on rpm when sprayed into lower carb. Is this normal?
Jiggz
Can you post pics of the reeds paying close attention to the petals? Others are defiantly against reversing reed petals but personally I have done it with success.
Jiggz
It looks like the petals are not sealing anymore. Personally, I'll reverse (or flip over) the petals that are not sealing while cleaning those that are sticky. Just make sure you use loctite thread sealant on every screws you remove and re-install.
exlration
I'll try that and see what happens. I removed the two upper reed blocks today to compare with the lowers and noticed they have about the same gap but no sticky pedals. I'm starting wonder if the sticky pedals are the cause for the two lower cylinders not firing consistently.
