Stefanczyk
- Jun 2, 2015
- 4
I replaced the seals on my 1990 50Hp force. I had the lower unit completely off. Now that it is reassembled I can adjust the shift linkage so it will go into forward and reverse when the motor is not running but neither when running. I can adjust the linkage to get forward or reverse, but not both at the same time. It seems like everything would work fine if there was more throw in the shift linkage (if it went further up and down). I have had issues shifting into reverse the last several years - it would make a clicking sound prior to engaging. Do my forward and reverse gears need to be replaced. Are there any adjustments that would increase the travel of the shift linkage?
