Been a lurker every since my dad gave me this boat, but I have not been able to figure out the problem and need help desperately! History, the motor is a force 120, ran great 5 years ago...the boat sat for 5 years and then given to me...Here is what I have done so far to get it going...
Compression check on all cylinders, good
Changed out water pump and a few seals in the lower unit, good
Changed out plugs/starter/fuel pump diaphram, good
Cleaned both carbs top and bottom, issue
The motor will start, and run, but the idle is very erratic and will not stay on for more than 5-10 seconds and shut off...I have tried to adjust the idle/air screw on the carbs to no avail but it is difficult to adjust them when the motor cuts off so quickly...Here are some issues I have noticed that could be the problem. The top carb doesn't seem to be "sucking air" or creating as much vacuum as the bottom carb. Also, the top carb isn't getting as much fuel as the bottom carb...when I give it throttle, you can see a good bit of fuel come up from the bottom carb valve and much less from the top carb valve through the opening. I'm not sure if the lower vacuum on the top carb is causing this or not. I have not checked the reed plates yet, but that is next on my list...
Another issues that happened today when working on it was I cranked the motor and increased the throttle to say 50% to try to get the motor to stay on...the motor did rev up but also pretty much went to wide open throttle and was stuck there! The key would not turn the motor off! even unplugging the coil packs would not turn the motor off until we unplugged all 4 coils and messed with the throttle 'stick" connecting both carbs to choke it off...that was really strange. After we got it off, we let it sit for a few minutes and decided to try to start it again....it started and was "stuck" in wide open throttle and we had to disconnect the coils and mess with the throttle stick again to cut the motor off!
I am new to boating but have an extensive history of working on automobiles (engine rebuilds, trouble shooting, etc) if that helps...I consider myself mechanically inclined so am trying to tackle this project myself. I am only able to work on it a few hours a week due to busy work schedule right now but any suggestions on what to try/do next would be greatly appreciated! Thanks, Paul
