Evinrude_NooB
- Jul 21, 2011
- 142
Last year I acquired a 'Free' boat with a Force 50. Spring is here and I started looking at the motor. I don't know what year the motor is because the plate faded. Long story short, I removed the cowl, cleaned all the junk/gunk in there, cleaned the carb, removed plugs and spray sea foam in chambers, compression tested (~120 on upper and lower), and cleaned the fuel pump.
After all that, I went to start it and it started. However, it idles rough and will stall if I don't keep my hand on the the throttle. Can anyone suggest what I need to look at next?
Thanks in advance for your advice.
