Im trying to get this old motor another chance at life. I dropped the lower unit to further inspect the water pump. The impeller is sandwiched between two steel plates and with one plate fixed in the housing. I'm wondering if there is supposed to be seal on the shaft. The impeller doesn't fit super tight on the drive shaft making me think that it can't do its job. It seems like all other impeller housing have seals on the shaft. Any help would be greatly appreciated.
