I went to warm up the boat today in the driveway using earmuffs. I got it up to temp then turned it off. I noticed a little bit of coffee colored water coming out as shown in the picture.
Dont know if related or not, but I did drain the lower unit lube and it was dark blue, no signs of water in the lube. I drained about 15 ounces of lube. I am not sure, but I think the capacity is 22 ounces. There is no stains in the garage where it sat all winter which would indicate a gear lube leak so I am wondering if this coffee colored water is normal and just from the exhaust? Or do I need to replace a gasket somewhere??
