thebigbat1988
- Apr 16, 2015
- 2
I have a 15hp gamefisher that has had the carb rebuilt soaked in chem dip new fuel lines and also had the fuel intake soaked as well . The motor cranks fine and idles fine goes into all the gears fine as it should . I have had a compression test done and no issues there either . It is getting good spark to both plugs as well . The problem is when I place the motor into the forward gear it starts out fine at a low but forward movement but when I give it full throttle it bogs down and want to almost shut off. I have found though that when I shake the motor rapidly while going the motor wants to pick up momentum and run better but if i dont shake it and try to do normal operation i get no power from the motor at all . I did find that the water propellar wasnt working properly and have ordered a new one . Would that have any issue with it as well? I have the manul and it shows also that there is a thermostat on this engine and It is no where to be found on this engine not even by the manuals pictures it shows . PLEASE HELP!!!!
