ive searched to old post and can not find an answer.i got an old 9.2hp(?)it's a 1965 I believe,wizard/Chrysler.model #oco6509a66.the points wires are stuck out from under flywheel,ones hook to condensor and other not hooked to anything.wondered if someone had a diagram of that wiring.have one ground wire that's grounde to motor.wanted to see if it fires before I buy a manual.it was a under the house find along with a 1967 clinton which I already have running.thanks for reading in advance.
jeff.
jeff.
