jdiesl
- Apr 12, 2015
- 13
1st post ever in any forum. i guess im a super troll of some sort.
well of course my 1994 force 40hp wont start so i been doina little investigative work. i took the "house" approach and just started treating problems in order to diagnose. rebuilds include fuel line and bulb, fuel pump, and carb, all the cheap stuff. i take out the plugs and they are wet. clean but wet. smells like fuel so i clean them off and re install. ignition. nothing. check for spark. (I know dont do that) its small but its surface gap and what do i know. re install. ignition. wont fire up. i pull the plugs and they are wet. the bottom a little more than the top but both wet. smells like fuel.
i think im getting water in my combustion chamber and puttn the fire out. looking back it tried to fire up the first time i hit the starter this year. i checked the compression . its the same on both cylinders but a bit low i think at 105. so i think my head gasket is fine. at which point if not earlier im out of my depth. i think the exhaust gasket but idk. anyone
