This is a classic got grandpa's old boat situation. From looking online, I believe the boat is a 1966 Lonestar Tracer. The motor is a Chrysler 35 hp ( model # 35601 serial # 1078). I started it up today and it seems to run okay. There is oil ( looks like thick milk) that leaks out of the water drain holes on the lower unit. When I got the boat, they said grandpa knew the lower unit had water issues and would just drain out the water after each use. What is the value of this method? As old as this motor is do I have other options( rebuild kit)? Any advice where to find a owners manual would also be helpful. Also is a 50:1 the right fuel to oil ratio?
I appreciate any info and any other advice on getting this boat back on the water.
