Mhenson327
- Apr 10, 2015
- 1
I have a 22 ft pontoon with a 1990 I believe force 90 hp. It has good compression but recently some problem, needs 2 new coils running on one cylinder, needs new trim motor and skag and prop are shot. I found a 86 force 85 hp for 300 bucks which the guys says runs and starts up great. I'm wondering if I purchased this could I use the parts to make one good motor and also if this one is good to go if the controls are the same and I could do a easy swap over. Thanks for any advice
