I have the Prestolite system which has a voltage output of 15K~40K volts at the ignition coil. The Thunderbolt ignition system is basically the same with 15K~40K volts going to the spark plugs. Misfires are one of the hardest electrical problems to troubleshoot especially if it is intermittent. Personally, I use a timing light for preliminary t-shooting as it requires very little effort to do so. Use the timing light bounced against a dark surface or paper and watch the consistency of the sparks (strobe of the timing light) on each plug in relation to the engine running tone. If you do not have a timing light you can also use the proper tool which is the in-line spark tester. If you come up with a suspect the only proper way to diagnose is to replace the suspected faulty parts with known working parts. Remember, if the strobe from the timing light misses (which should be the same for the in-line spark tester) THE PROBLEM IS NOT THE SPARK PLUG BUT RATHER UPSTREAM OF THE SPARK PLUG, i.e. ignition coil, CD modules, switchbox, trigger wires, etc.
