Bullie
- Dec 20, 2014
- 300
I picked up a 1984 Chrysler Sea King 9.9 model VWB52299D today as a project. Looks like it will be one. I started tinkering with it this afternoon and I couldn't get it to shift into reverse. It goes in neutral and forward fine. I dropped the LU to see what I could see and could only get reverse to engage one time with the shift rod. What should I do?
I checked the water pump while I was in the LU, all good there. LU lube looks new. It has no spark but I should probably worry about that after I find out if the LU is goofed up right?
