I just got an 89 Force 125 and brought it back from 10-15 years without service. The impeller is a question mark but it's spitting water from the pee holes when hooked to the hose/ear muffs. It's not spraying a stream but it is spitting some out and a lot out of the exhaust hole at the lower unit. This is all after the engine warms up some (thermostat opening I'm guessing).
Do I need to change the impeller?
I'd like to make sure the buzzer and overheat sensor are working as well. I'd assume the buzzer could be tested by connecting to voltage, but the sensor would have to basically reach whatever temp is overheated. Not sure how to do that.
