I found a nice project boat and am getting it running. It hadn't been started in about 6-7 years. I checked compression and all 4 cyls have around 135 psi. I pulled the plug out of each cylinder pushed the ground side against the chassis, and watched as someone cranked and all but the 3rd from the top had a regular rhythmic spark. The 3rd from the top seemed to be kind of intermittent. I also am hearing a confirmation when the engine is idling (just started it for the first time today and it has a slight irregular misfire).
So, I think that tells me what I need to know but wanted to make sure I'm not missing something. Also, I noticed that there are 4 Blue Coils with plug wires and two other Blue things that also seem like coils. I'm not familiar with the Force ignition system so I want to make sure before I throw a coil at #3 that it's not something else. I also swapped plugs around and they are fine.
