Hi y'all, first time post. I've been having issues with my force 125 since cleaning the carbs. Here's the deal. The boat starts up just fine and idle well. It'll go wot for about a minute then it Boggs way down. I've had the boat for a couple months and it was running ok, had a miss so I figured id clean the carbs. Took off the bowls took off float and valve. The problem is I was not so smart and messed with the float height. Does anyone know how to reset the float height? Thanks
