nnk_boater
- Sep 2, 2009
- 22
I just installed a brand new 130 degree thermostat, Quicksilver part number F664068 from a lot dated 09/07/10. I notice that there is no tell-tale stream. I remove the freeze plug, connect a hose and I have enough flow to put out a 5 alarm fire. So, why is the thermostat not opening? I take it out and test it with a digital thermometer and it does not open until 148 to 150 degrees. I've arranged with the dealer to swap for a new one. The thermostat is stamped "130". So, am I being too anal? What's 20 degrees give or take going to do?
Prior to replacing the thermostat, the tell-tale stream started right after starting the motor, but the original thermostat was broken - stuck open.
