OK, I had to think a bit this as after 50 years boats and M/C's, theres a better product I've used. And theres no build up WD as ya only do it once. "Little Dab will do ya". Want off? Simple Green soaked and hose it off. But, learned long ago from a Harley wrench NOT to use WD on say clutch and brake exposed cables, as attracts dust and dirt, road grime. Said use this instead. This might be what the waxy stuff ya talking. Coat once, and forget it. Stuff works and made for it. Damn, seems I cant do the link IBoats. Just search CRC Marine corrosion inhiberter
