nnk_boater
- Sep 2, 2009
- 22
My fuel pump check valves are shown here with retainer rod installed. The check valve has a plastic disk only. The rebuild kit (Sierra 18-7817) has a clear plastic disk and a rubber disk. The service manual shows these as plastic disk and check valve. If I follow the manual, I install both. However, I've read that the check valve should be installed omitting the rubber disk (use plastic disk only) for the new ethanol fuel. This would also be consistent with the check valve assembly before I started the rebuild. Opinions?
http://i27.photobucket.com/albums/c194/nnk_boater/Fuel Pump/check_valve_zps7209d07a.jpg
http://i27.photobucket.com/albums/c194/nnk_boater/Fuel Pump/manual_zps714b01c2.jpg
