home-boy
Banned
- Aug 10, 2014
- 209
I hanged the new to me 1986 Force 125 on my boat last night. I need the tilt raised up so I wired that portion this evening and it did not work. PO must have been monkeying with it because the bolts that hold it together were loose. I tried to get them started and in the end the whole motor came apart.
It is filled with oil and grease so I will be cleaning it out tomorrow. I've seen the insides of a starter before and everything inside mine looks serviceable if I can get the brushes into position.
How do I put this thing back together?
