Hi and how are you? i need complete instruction or guide on how to set timing on 1997 force 120hp. just installed the engine because old engine was frozen. so i bought a good used engine.
i need help and input on what to do to set the timing and where should i set the timing and how many degrees.
how do i go about setting the timing
